Oil thermostat >
Oil thermostat
Oil thermostat
Old 03-18-2018 | 09:16 AM
splashandburn's Avatar
Default Oil thermostat
I'm trying to locate the oil thermostat on my 500 EFI's. I see the oil cooler but I can't see anywhere that there would be a thermostat. Can anyone help direct me? Thanks.
splashandburn is offline
Old 03-18-2018 | 11:54 AM
Isn't it in your oil filter mount on the back of the engine?
getrdunn is offline
Old 03-18-2018 | 12:20 PM
BUP
MerCruiser Race Engine & Drive 500 EFI Oil Cooler & Oil Filter (Engine) Parts
here easiest way for reference in the link above.
number 13 is the oil t stat and how the whole assembly is installed 12 thru 18
BUP is offline
Old 03-18-2018 | 03:00 PM
Thanks. I can see the cooler but not the housing. Guess it must be buried somewhere back there. Probably have to try to follow the hoses to find it.
Old 03-18-2018 | 04:00 PM
It’s in the adapter that goes to the oil filter pad on the block.
Unlimited jd is offline
Old 03-20-2018 | 04:01 PM
The filters are remotely mounted on the front of the motors. There's nothing on the mounts except an oil temp sensor.
Old 03-20-2018 | 08:46 PM
Rookie's Avatar
Double post
Rookie is offline
Old 03-20-2018 | 09:11 PM
take a better look. There’s an adapter where the filter would go if it was on the block. The thermostat is in there.
Old 03-21-2018 | 08:21 PM
You find yet. This is a hp 500.
getrdunn is offline
