Noise reduction with dry headers >
Old 03-27-2018 | 01:44 PM
Default Noise reduction with dry headers
I have a 29 Fountain with a strong 540 with CMI Sport Tube headers and 4.5 tails. I have a Howard cam with a 114 LSA 242 254 duration at .50 degree, Brodix BB-2 aluminum heads, 10.5 compression, with a Holley EFI. I replaced the Bravo drive with an IMCO SCX upper with a SC -2 lower. I plan on running a 5 blade prop. About the only thing I need is something that will temper the sound of a BBC with straight pipes. I have found two possible options, Harden Marine HCX Series Offshore Mufflers and GGB inserts. Both mufflers are inserts in CMI Tails. Has anyone had any experience with either of these options? I need to get one of these or something else so I can get my boat in the water this spring.Thanks for any feedback.
ar300johnson is offline
Old 03-27-2018 | 03:18 PM
Ive never used those, but I have used these. A small hole drilled into the end of the tailpipe will allow just enough water thru to keep them cool. They are effective at reducing the noise when closed.
1220 GAFFRIG SUPERFLO SERIES MUFFLER 4.5I.D. TAIL PIPE (1-PAIR) INCLUDES PUMP KIT
MILD THUNDER is offline
Old 03-27-2018 | 03:31 PM
GGB,S work great but you need water through them to work proper .
575cat is offline
Old 03-28-2018 | 05:51 AM
I have dry exhaust as well and the only thing I have found that will work without cooking are the GGB's. Those Gaffrigs will most likely eat themselves up from the heat and turn brown.
corey331 is offline
Old 03-28-2018 | 06:44 AM
I have ran them with dry stellings exhaust, with water that dumps at the very end. No issues. A friend had them on with only a small 1/4" hole at the end of his tails , and rest of water going thru overboard dumps. They dont turn brown as long as you have a little pizzer of water to keep them cool. A small amount of water needed to cool them should not cause any reversion issues .
Its nice being able to close them around the docks, or launch ramp, and open them when up and running.
Old 03-28-2018 | 07:46 AM
Revelocity's Avatar
I've also had no issues running GGB inserts in my dry CMI tailpipe where the water exits at the rear edge of the pipe adjacent to the inserts.
Revelocity is offline
Old 03-28-2018 | 07:14 PM
ROB FREEMAN's Avatar
cmi sound elimination work good too
ROB FREEMAN is offline
Old 03-28-2018 | 08:57 PM
Thanks for the replies. I believe that I will go with the GGB’s. I have already spent too much on this project and the GGB’s are the least expensive option. Again thanks.
Old 03-28-2018 | 11:24 PM
I’m always pumping the GGB inserts here simply because they are so effective with near no drawbacks. Someone at one time even made a case for them actually help fight reversion but I have no way of substantiating that. I put the 5.5x4” units in my wet tails and it *felt* like it cut the sound in half.
Baja Rooster is offline
Old 04-02-2018 | 10:26 AM
Panther's Avatar
Frank's Marine Service
Small weep hole at the top of the pipe and then run bolt the mufflers on. I did this for about a decade on my dry exhaust (both headers and manifold setups).
Got divorced and pulled the mufflers off 4 years ago a week after separation....lol Buh bye mufflers! Possibly sell them as they're collecting dust in my loft.
Panther is offline
