-   -   Which head gasket to use BBC salt water (https://www.offshoreonly.com/forums/general-q/353096-head-gasket-use-bbc-salt-water.html)
pjv911 03-31-2018 08:28 AM
Considering the following.
Cast Iron heads
Zero deck height
Cylinder notch reliefs
Bore 4.280 (.030 over 454).
Which head gasket should I chose?
The engine will be run exclusively in salt water.
Rookie 03-31-2018 05:41 PM
MK IV, Gen 5 or 6?
FelPro 17042, 17046 or 1037
seafordguy 03-31-2018 07:26 PM
I used cometic (if you're asking for brand recommendation)
pjv911 03-31-2018 08:57 PM
Gen VI
pjv911 04-02-2018 09:16 AM
Originally Posted by Rookie (Post 4618938)
MK IV, Gen 5 or 6?
Rookie, I do Not have a 4.370 bore size. Is there a reason you are recommending these part #'s for my application?
Is this board dead or what? Its like a ghost town around here.
Rookie 04-03-2018 07:57 PM
4.370" is the common bore size for a head gasket for a 454. A 502 is 4.540".
17046 is just a quality low cost head gasket for a marine build. I have run the same ones 10yrs on some ~600HP 454's with no issues, I may have reused them once... lol And the 1037 is the exact same head gasket just part numbered for automobiles. Gaskets with the 17 are marine. I am putting 17042's (standard HP) in my 420 builds right now. $31ea from summit, free shipping on $100 orders. And going to go with the 17046's (High Performance) for my 575HP builds.
mike tkach 04-03-2018 11:25 PM
10 years,when i recomended the exact same head gasket i was told they won,t last and you need to go with a mls gasket,i like you have used these with great results on a lot of engine through the years,last year i rebuilt one that has not had the heads off for 13 years and all was good.
getrdunn 04-04-2018 10:46 AM
Like rookie said the 4.370 is a common head gasket size and safe with a bore up to .060 in most cases. Just confirm your heads are stock and or at least the fire ring doesn't protrude out into the chamber. Just match it up to the head prior to installing. That's good info that rookie gave you and have used and reused same ones when in a crunch during overnight overhaul (gotta get on the water next day type thing). What can I say it happens. Head gaskets can get ridiculously expensive... I can't personally confirm same for salt water.
Panther 04-04-2018 03:22 PM
Block is zero decked, correct? I think .039 is a little tight on quench. Personally, I'd go with next step up if it were me..
Panther 04-04-2018 03:54 PM
I also recommend spraying the Felpro's with Permatex Copper Spray-A-Gasket . Over the years I found that it really cuts down on seeping between the block and head that leaves those ugly rust stains down the side of the block.
