Gen 5 efi system on to Gen 6 mag? >
Old 04-05-2018 | 12:58 AM
Default Gen 5 efi system on to Gen 6 mag?
Hi guys, hopefully a fairly straight forward question. A friend of mine has a complete 502 EFi system he’s taken of his engine as he’s going over to carbs. I’ve got a spare Gen 6 454 mag, rect ports, is the 502 system going to bolt on?
Cheers
Tim
T1MWV is offline
Old 04-05-2018 | 10:03 AM
Yes. Those engines are essentially the same other then a different timing cover and the GenV was not a factory hyd roller and the Gen VI is. You may have to change cams in the Gen V if you plan to use the ecm with the existing tune.
Eddie
Young Performance is offline
