I think i lost TDC. HELP >
Old 04-07-2018 | 07:12 PM
bck's Avatar
bck
Charter Member#568
You mentioned that you found top dead center but you haven't said that you've verified it was top dead center on the compression stroke. Like F2 said, you need to verify which stroke it's on.
Straight bottoms and flat decks
bck is offline
Old 04-07-2018 | 07:33 PM
If you doubt that you are at TDC on the compression stroke, then rotate the engine by hand while watching the #1 intake pushrod/lifter/rocker arm. It will open and then close. When the balancer hits 0 after the #1 intake valve closes, you are on the compression stroke. You can't go wrong by just tightening them down as they have a non adjustable valvetrain. Sometime the lifter will pump up with oil and not release fast enough when you crank down on the rocker causing the spring to compress. It will eventually go down. It usually only takes a minute or so.
Eddie
Young Performance is offline
Old 04-07-2018 | 11:41 PM
The cams need to be set in relation to the pistion. The Piston doesn't care if it compression or exhaust. Set #1 Piston at tdc. Then index the markings on the cam gears . If this is not an interference engine then you are free to rotate the cam with the heads on. Once set the timing chain keeps the rotating parts rotating in squence.
justfishing is offline
Old 04-08-2018 | 01:56 AM
Since the cam and timing chain set have not been touched, just torque down the non adjustable rocker shoulder bolts to I think 35 ft lbs.
Originally Posted by GPM
TDC will come up on the damper at 1 and 6, see which cylinder has both valves closed and that's the cylinder you're on.
rule of thumb to find TDC put your finger in the #1 hole and spin it around if it doesn't push air out the exhaust valve is open one more time around pushes your finger out with air, compression stroke for TDC.
Correct, but can't do or see that until the rockers are installed.
Griff is offline
