-   -   24 (22)x7 X-dim (https://www.offshoreonly.com/forums/general-q/353267-24-22-x7-x-dim.html)
phragle 04-08-2018 08:45 PM
24 (22)x7 X-dim
I was at 15 7/8" Has any one ran 18" how did it work out?? Getting ready to cut...
outonsafari 04-09-2018 06:55 PM
cannot believe there has been no feedback on a 24 7 x dimension.
what boat is this, the one from the guess how fast it'll go thread ?
phragle 04-09-2018 07:09 PM
https://cimg7.ibsrv.net/gimg/www.off...4bfd7fc3f1.jpg
Yep...major time setbacks but the new motor should be lit off next week, the glass work is done, just need to cut a hole....
Boatally Insane 04-09-2018 08:03 PM
I went with 18.5" X on my 26' Corsa..
ran GREAT. !
https://cimg3.ibsrv.net/gimg/www.off...1c9f974fe5.jpg
phragle 04-09-2018 09:22 PM
ran GREAT. !
No problems planning or blowing out??
tommymonza 04-10-2018 05:54 AM
When Planning. , Always go with the grain and be sure your blade is sharp. Use bathroom before planning to avoid Blowouts
tommymonza 04-10-2018 05:57 AM
Proper planning will avoid blowouts before going on Plane. And avoid seats near babies, even if their mommies are Hot.
Boatally Insane 04-10-2018 04:09 PM
Nope.. NO issues planing running 4 blade props.
One season it had a 454 mag in it, I built out of scrap.. It Knocked, but ran 68 MPH with a 26 Bravo I lol
The Only issue it had was when I originally had the tabs mounted parallel to the hull, the stern would skate sideways when trying to correct a list.. Not sure if my high X was a contributing factor or not.. I ended up re-mounting the tabs flat and it worked GREAT...
I did put my 555 in it without the blower for a bit.. ran 86 MPH (630 hp)
https://cimg4.ibsrv.net/gimg/www.off...dc563c0415.jpg
mbobb 04-11-2018 06:14 PM
My 22' Avanti was set at 16.19" from the factory I think but it's tough to measure accurately with the small curved "delta pad". I plan on raising mine this coming winter if all goes as planned. From everything I've read on here in the past it sounds like Pantera recommended 17 but then Thomas had his mounted at 18ish and it worked great with certain props. I plan on cutting mine at 18.5 and then spacing down if needed. Post some pics when you're done please.....I'm curious to see how the transom looks when its finished
mbobb 04-11-2018 06:22 PM
Here's how mine looks now......I went with a 3" taller exhaust last year since I hated how low the original exhaust was. You can see I still have height to move everything up a few more inches with the +3" risers
https://cimg5.ibsrv.net/gimg/www.off...247e058bac.png
