Estimated HP output - Build Sheet attached >
Old 05-14-2018 | 08:17 PM
  #51
A 4780 holley 800cfm, came with 71p, 85 secondary.
seems like alot of jet you have for those carbs. I bet its really fat
MILD THUNDER is offline
Old 05-14-2018 | 08:23 PM
  #52
I believe I’m at 74 and 82 on my 502, and gained about 400 rpm dropping down from 88s.
Baja Rooster is offline
Old 05-14-2018 | 08:35 PM
  #53
I'm going to take a look at the plugs next.
Do you think the factory HP500 jetting would be a good (safe) place to start?
AWOL is offline
Old 05-15-2018 | 08:13 AM
  #54
My quick fuel M-800's came with 78/86 ... They also came with standard 6.5 pv's .. wonder why you have the 3.5? Seems like a big jump in power valve for such a mild cam.
TylerBurich is offline
Old 05-15-2018 | 10:11 PM
  #55
Previous, previous owner did the vacuum test and settled on 3.5pv. In the notes I can see they said there was a fuel smell at idle, and what caused him to check. Apparently the 3.5pv cured that
AWOL is offline
Old 05-15-2018 | 10:37 PM
  #56
one of the biggest misconceptions in the carburetor discussions, is that power valve opening point, can have an effect on idle mixture. The ONLY way a power valve can make a rich mixture, is if it were blown/ruptured, where engine vacuum will pull fuel thru the diaphram. When a power valve opens, it enriches the main circuit, which is inactive at idle. The idle circuit is what is active at idle.
Old 05-16-2018 | 01:13 AM
  #57
For reference, On my 32 AT, I spin 24 Bravo's to 5100rpms with 502mpis with CMI's (425ish hp) and 1.36 Bravo drives on ext boxes for 72-73 mph.
Griff is offline
Old 05-16-2018 | 08:02 AM
  #58
That diagnosis would only mean the power valve that was in it was blown or leaking, I don't really think you can "blow" a power valve very easily on these newer carbs. Check your idle vacuum again, you may need a different power valve... and jet accordingly.
Old 05-16-2018 | 09:33 AM
  #59
bck's Avatar
bck
Charter Member#568
once upon a time they sold kits to prevent power valve blowouts (usually due to a backfire). Then some of Holleys competitors started including power valve protection standard. I have know idea what the current situation is.
Straight bottoms and flat decks
bck is offline
Old 05-16-2018 | 09:50 AM
  #60
convincor's Avatar
They still have them. I believe the became standard after '92
https://www.holley.com/products/fuel.../parts/125-500
convincor is offline
