Which intake manifold sbc 350 >
Old 04-10-2018 | 01:39 PM
Default Which intake manifold sbc 350
Trying to choose between two intake manifold
Edelbrock performer
Edelbrock RPM Air Gap
sbc 350mag
afr 180cc 65cc Heads
scorpion roller rockers 1.5
comp cam x4270hr
which intake manifold would be better ?
hotshot537 is offline
Old 04-10-2018 | 03:29 PM
RPM Air Gap is my vote.
I ran a similar setup. AFR190R's. XM276HR. 1.6 rockers. RPM AirGap.
https://youtu.be/vuL_dEX0SoM
Ryan00TJ is offline
Old 04-10-2018 | 04:00 PM
GPM
Depends on the RPM range you expect to run.
GPM is offline
Old 04-10-2018 | 11:43 PM
Well I like to cruise at 3000 RPM And never really run boat over for 4500rpm
except for speed tests then I’ll run it to 5000rpm
Old 04-10-2018 | 11:45 PM
what prop are you running
Old 04-11-2018 | 01:57 PM
GPM
I would say the Performer for that RPM range. I could be wrong.
GPM is offline
Old 04-11-2018 | 04:09 PM
With that engine it was a 23p Mercury TRS 3blade cleaver labbed by Hydromotive. Spun 5500-5700rpms. Your setup should peak 5200 + rpm. What exhaust?
Ryan00TJ is offline
Old 04-12-2018 | 05:24 PM
Right now I’ll be running stock with y pipes next season I’ll probably put in the through transom exhaust
Will be doing the work in the next couple weeks to get everything put together but right now it’s a stock 350 mag with the upgraded cam and I’m spinning a 14 19 @50mph @5000rpm 21sr br advantage with 6 girls and 2 ice chest full of beer
just trying to pick up my cruising speed more that’s why I’m doing upgrades right now It 30mph @3000 with the 14 19 offshore prop but it blows out at full throttle so I have to watch that 21 bravo one It’s a little too big still
