Stud girdles a good idea? >
Old 04-13-2018 | 01:36 PM
Default Stud girdles a good idea?
I’m curious how many people here use stud girdles. It seems like cheap reinforcement for a delicate valvetrain. My own build is mild 10:1cr, 525EFI cam that may see 6k from time to time. While it’s out it seems like a good idea to put them on?
Baja Rooster is offline
Old 04-13-2018 | 02:17 PM
I've always run them on the higher performance engines, particularly if I'm running solid rollers. The ramp speed is more significant placing a higher lateral load on the stud, and I've always noticed (real or perceived) that the valve lash stayed the same longer with girdles. You have so much money in them already, it's just cheap insurance as you said. Beside.....if some is good, more is better!
CDShack is offline
Old 04-13-2018 | 03:11 PM
F-2 Speedy's Avatar
these are the only ones I'll buy, Webster Industries, the fitment is spot on..
F-2 Speedy is online now
Old 04-13-2018 | 04:18 PM
GPM
A good set of stainless shaft rockers is even better
GPM is offline
Old 04-13-2018 | 04:58 PM
I have Comp Cams magnum pro rockers.
Old 04-13-2018 | 10:10 PM
Tinkerer's Avatar
Jessel shaft rockers are on my 598
Tinkerer is offline
Old 04-14-2018 | 07:56 AM
I'm running TD shaft rockers on my 572's.
endeavour32 is offline
Old 04-14-2018 | 08:57 AM
F-2 Speedy's Avatar
..... Baja R you can spend 275-300 bucks and accomplish what you want or 1600-1800 per engine for over kill for your engine
Old 04-14-2018 | 09:22 PM
Full Force's Avatar
Agree, I was very happy with mine also..
Full Force is offline
Old 04-14-2018 | 09:31 PM
Rookie's Avatar
If you have to start fresh, studs, rocker arms, guide plates and girdles. Yella Terra pedestal mount rockers are the way to go without going full shaft rockers. $800-$1000 Saw them at PRI a few years ago and will be switching to later, probably for this years builds.
Rookie is offline
