-   -   29 outlaw (https://www.offshoreonly.com/forums/general-q/353392-29-outlaw.html)
Ty95 04-15-2018 04:31 PM
29 outlaw
Need to change mechanical trim cables and was wondering if anyone would know how long they are I'm guessing one is shorter then the other but I would like to pull the new cable thru with the old one thanks
Rookie 04-15-2018 05:48 PM
The cables have the lengths on them near the ends. Just disconnect and look within a foot or 2 of the end.
Griff 04-15-2018 10:05 PM
The length is in inches and 1-2' from the ends as Rookie said.
Its not a fun job. I just finished doing mine.
BUP 04-15-2018 10:23 PM
we tie a special string fish when pulling out and then tie that fish to the new cable. The string fish I have is old timer stuff that telephone installers used to tie down and fish cables in the central offices were all the big phone equipment was installed including later on fiber optics installs. It is waxed coated string and strong as hell, leaves no marks period. Glides very easily and does not cut into stuff compared to if one would use fishing line as a fish. Works great and does not tear up stuff like a metal wire fish does.
Ty95 04-16-2018 11:33 AM
Thanks I will look when I get home tonight what would be the best cables to replace them with I seen on here some people said to stay away from the 33c cables and go with the teleflex just wondering which last the longest only run in lakes and rivers no sea water
F-2 Speedy 04-16-2018 11:51 AM
33c or 3300 is the type of cable ends on the cables, Teleflex is fine, there's an extreme one also I think it has tighter bend radius characteristic's ?
Ty95 04-16-2018 12:34 PM
Thanks I looked for numbers on both sides of cable can not find no markings guess I am not going to have a choice but to pull cables and measure them
Griff 04-16-2018 01:06 PM
I used the TFXtreme ( Teleflex Exteme)
https://www.go2marine.com/product/88...html-401745000
Fishing the cable through was no big deal. Getting it connected to the indicator through an 18" x 24" hole behind the dash was the difficult part.
Ty95 04-16-2018 01:23 PM
Thank you I kind of figured it was going to be fun hooking it up to the gauge didn't seem like they gave you very much room going to pull cables out tonight and order and then let the fun begin lol!!
Ryan00TJ 04-16-2018 07:29 PM
I replaced mine with UFlex Mach series cable. Very nice quality.
