Strainers, stainless or aluminum?
IMO eventually the anodized coating will start to compromise and the aluminum will corrode espically in salt water. Good quaility stainless like 316 will last basically forever if taken care of.
Doing a lot of my boating in salt water if I was going to buy a boat I see the aluminum pieces as a negative. I Also see painted trailers as a negative.
I just recently bought a Hardin Marine 316 stainless strainer. It was a little more expensive than the 304 stainless version. When I was looking to buy the strainer I stayed away for any that had any aluminum.
Just my. 02
Just my. 02
Cast aluminum will actually begin to “dissolve” when introduced to water that has an ion/negative charge to it. While this does not seem very important, when boating on a lake that is used to cool a nuclear power plant, this is the case.
I always wondered if it had something to do with the nuke plant!
For boats that are regularly used in fresh water lakes like this, there is a different type of anode that should be used. IIRC, it's Magnesium.
Mercruiser Sterndrive Magnesium Anodes
