Hardin Marine oil filter mount leak fest
My failure is odd. Raced the piece for over a year zero problems. Leake formed and can see no defects. I use all hardin Marine accessories on our engine and they have always been reliable and well thought out. The tech support at Hardin is great and I am still a customer just a very odd failure.
Steve
Steve
Steve
Steve
It’s a gorgeous piece. But what a pita to seal up. The best luck that I’ve had on the threads is Permatex Aero form-a-gasket with yellow tephlon tape on the last row of threads on the fitting. Hokey af, but hopefully I get better seal when I redo everything on the new engine.
Have this part and had the same problem. I finally found the leak was from the mounting bolts in the bracket. Thread sealer cured it I was sure it was leaking at the top of the filter also until I seperated the bracket and could see the oil between the two parts. Good luck.
was the bottom (s) straight edged across to make sure all that was level and straight from all cross sections ? Can you give out the part number for this mount ? thanks
I would look at the bottom portion with a powerful magnify glass to see if any porosity is present.
I prob will ask them about it to see what their take is on it. Rick at CP is very helpful plus on top of everything Surely CP / Hardin / KE ---- they do not want to see anything like this happen either.
I have not read the thread, I don't have to. Everything I've bought from them had issues. Oil pans did not fit, oil adapters didn't fit with their own pans , pans rotted out in 3 years( in a brand new boat mind you. The headers leak every year which I just keep a eye on and fix as needed. I've heard some good things by some but not me . I did however get good service from Mike mays when he had some tails made for me but I bet they came from a shop with people that care about a decent product.
