LSA swap, trying to figure out throttle linkage/cables? >
Old 05-02-2018 | 10:30 AM
Default LSA swap, trying to figure out throttle linkage/cables?
Seeing if anyone has any ideas here. The factory linkage 33C cables are a stiff ended design with about 3" of travel. The factory TB on these engines are a cammed design with a flexible cable. Cable comes over the top and goes around the cam then hooks into one of the holes on bottom. Length of pull Id say is roughly 1.5-2"
Might be able to affix std linkage to the throttle cam with some kind of swivel pin, but is there a way to change the length of travel in the shifter itself?
GrannySShifting is offline
Old 05-02-2018 | 12:54 PM
On many types of throttles, you can adjust the amount of throw by connecting the 33cc cable in a different spot on the bottom of the lever.
Griff is offline
Old 05-02-2018 | 11:52 PM
These Keikhafer controls only haveone place tomount them. Posted picture on another thread somewhere on here when i asked if it was possible to flip them
Old 05-03-2018 | 08:05 PM
LSA is drive by wire
i dont think a cable unit will clear the cooler
LTZCrew is offline
Old 05-06-2018 | 01:34 AM
its not a whole LSA pullout. LSA blowers on different shortblocks, custom throttle cable bracket I use on drive by cable swaps
Old 05-06-2018 | 07:40 AM
make a arm and attach to the cam bringing it up to get a strait line with a bracket you will have to make to of intake. play with heights to get the ratio that works with your throttle assy.
ezstriper is offline
Old 05-06-2018 | 06:28 PM
they make a DBW to cable adapter if you already have the LSA thorttle body. was looking at doing this a year ago, that way you can run the cable to where every is easiest to mount and it should plug n play with the LS/LQ harness
https://marineenginedepot.com/MP/Mar...-with-Bracket/
LTZCrew is offline
