mercruiser trans >
mercruiser trans
mercruiser trans
Old 10-22-2002 | 09:46 PM
excaliber
Default mercruiser trans
how much power can these trannies hold before they break?or would i be better off switching to some b/w trannies thanks.
Old 10-23-2002 | 05:53 AM
rws's Avatar
rws
I have been told 500 hp if another forward clutch is added.Tom Huber or Marc Berman can modify these for additional hp.
Rob
rws is offline
Old 10-23-2002 | 07:24 AM
Audiofn's Avatar
Charter Member #232
The real question is how good are you at throttling and how heavy is your boat? I have a friend that runs a boat with over 650hp in it. If you change over to the BW transmisions you will go slower with the same power as they eat a little more power up. They will also require you to move the engines forward. I will be puting in the area of 450+hp into my boat when I repower and I am not worried about it at all.
Put your best foot forward!
Audiofn is offline
Old 10-23-2002 | 07:30 AM
Zanie's Avatar
Excaliber?
Excalibur!
Zanie is offline
Old 10-23-2002 | 07:49 AM
FWK
EXCALIBUR! 450-500hp and you are on the edge at that time. Huber charges about 600 for the rebuild and the upgrade. You supply the seal kit which comes complete from mercruiser. What model excalibur. Hey Zanie how are things going? Forrest
Old 10-23-2002 | 10:01 AM
Am running well over 500 HP through an upgraded MercTrans II with Amsoil Race (no slip) synthetic. Over 500 hrs. with no problems in that area at all. --- Jer
jpclear is offline
Old 10-23-2002 | 12:32 PM
FWK
JP what type of boat do you have. It makes me feel confident that mine will hold up. But my 27 does not wiegh a lot. Forrest
Old 10-23-2002 | 12:49 PM
Biggus's Avatar
If you decide to run the MercTrans, they will last a lot longer if you underprop a bit and spin the motors a little higher. Stay away from 4 blade props. If you load these trannys too hard the front pump gear will split in half
I`ve blown up more of these than I care to admit
Kurt.
Biggus is offline
Old 10-23-2002 | 09:31 PM
FWK: Am running 548 cid in a '77 Martini 7 meter (25'). Dry hull weight w/mechanicals was origionally supposed to be about 3500#. I don't hammer it out of the hole but it flys on occasion since it does top 80 MPH (GPS) on the good condition days. Have made several upgrades since I acquired her in '82 (bow tie block, K Planes, stringer & bottom beefing, raise X-dim, transom notch, but I still think that I would weigh in at under 4K.dry. Am running a several times reworked Spinelli 4 blade 29 (probably about a real 28 now) at 53-5400 on those good days. This was all probably much more than you wanted to know. Later! --- Jer
jpclear is offline
Old 10-24-2002 | 12:35 AM
Biggus's Avatar
JPC, wow, have you had any tranny problems?
I have had the MercTrans in a few boats and I got pretty good at rebuilding them Had a 24 Superboat with a Gale Banks twin turbo big block and a 29p Mirage. I could blow the tranny every time I firewalled the throttle but I could make it last a lot longer running a 27p
Biggus is offline
