Eliminator garage scene >
Old 02-17-2003 | 08:08 PM
  #51
Lovin aint the only thing!!! I am aware of what your saying about the mdf. I used 3/4 inch plywood and ran the grain thin the strongest direction. Its glued and screwed as well. No its not resined either but I'm figuring that Ill need new subs soon. I bought these Orion Extreme xtr 2250 amps with fans on them and the guy I bought them from said that he had a hard time keeping a set of speakers around. Subs that is. So I may be back in to those boxes And at that time I will have to fix it. The boxes have .91 cu ft volume now. Correct me if Im wrong but if I glue mdf to the inside of my existing boxes won't I further reduce the volume? How critical is that volume? The front of those boxes are only 1/2" thick ( the original upholstered panel,) but most of it is cut out for the speaker. Have you ever heard of Orion amps? Greg
HPJunkie is offline
Old 02-17-2003 | 08:09 PM
  #52
Audio,
Any new pictures on your project yet?
HPJunkie is offline
Old 02-17-2003 | 08:28 PM
  #53
Audiofn's Avatar
Charter Member #232
Yup I have heard of Orion amps. They are VERY Good. They use up a lot of power so you may find a need for a second house battery. They do have GOBBS of power. The reason the subs are blowing is incorrect enclosures (just like my story) If I had build the enclosure correctly then that would not have happened. If you are not building ported enclosures then you are at a advantage as to design. They are MUCH esier to build as you just do so to the enclosure. You could build the boxes baffle (the part the sub mounts in) and put that up against the back of the trim piece that you are saying is thin. 1/2 inch material is REALLY to small. I like to go 1" for my baffle. To answer your other question about the box size changing yes you will change the volume. You just have to measure the box and find out if the new size is ok for the subs you have. If you are a little small that is ok. STUFF the box with Polly fill
You should NOT have a problem with blowing your subs. Not if the stuff is set up correctly and boxes built properly.
Jon
Put your best foot forward!
Audiofn is offline
Old 02-18-2003 | 07:45 AM
  #54
Where do I get poly fill? Is it the same as the pillow stuffing? Greg
HPJunkie is offline
Old 02-20-2003 | 10:08 AM
  #55
Hi guys. The motor is still not in and the beers gone! I'm off the highway and on the dirt road again with little side projects. The fuel system reared its ugly head so I slayed that thing and then the solenoids, relay and plug-in had nowhere to go so I made bracket for those things. Maybe this weekend I can get something done! Heres the latest progress...Fuel regulator
HPJunkie is offline
Old 02-20-2003 | 10:10 AM
  #56
I looked at some pictures of some HP500 brackets and made this one. I hope it clears.
HPJunkie is offline
Old 02-23-2003 | 04:55 PM
  #57
Elite Marine's Avatar
HP -
Looks great so far. Is that an electrical sending unit on the fuel regulator? Running a blower, I'd go with a mechanical gauge if I were you. You know how critical fuel pressure is to a blower motor. Just my 2 cents.
Looks nice!!!
Elite Marine is offline
Old 02-23-2003 | 07:18 PM
  #58
GLH's Avatar
GLH
Originally posted by HPJunkie
GLH, Thanks ...I hope its mean enough! Is that your boat as an avatar?
No a reasonable facimilie. Took delivery in January and here in VT I have had better luck with my car on the lake than any boat this time of year!
Here it is in the shop.
GLH is offline
Old 02-26-2003 | 01:13 PM
  #59
Nice Cig! What year is that? What motors does it have in it? Greg
HPJunkie is offline
Old 02-28-2003 | 12:12 PM
  #60
Finally got it in! Its aligned and ready to rig. Now I have to mount my Msd, batterys, switch, Oil res., trim pump, diamond plate, and more. Whew its still alot. More photos to come.
HPJunkie is offline
