mirage solid hub prop >
Old 05-14-2018 | 06:17 PM
Default mirage solid hub prop
i just got a mirage solid hub prop i would like to know what thrust washer i would need to put it on a alpha 1 gen 2 thanks
mira boater is offline
Old 05-14-2018 | 08:29 PM
Ratchet's Avatar
I used to solid hubs, but had them on a gen 1........Not sure if the Gen 2 uses the same thrust washer, but the part number on the one I have on my tool box is 12-835467-5.
Like I said, I am not 100% sure if this is the same, but maybe it may help you get started.
Ratchet is offline
Old 05-15-2018 | 02:25 AM
That is the correct one you need, 12-835467-5. Here's the cheapest place you can get it with free shipping. https://www.ebay.com/itm/Mercury-Qui...75.c100623.m-1
picklenjim is offline
Old 05-15-2018 | 06:55 AM
Mbam's Avatar
Offshoreonly Advertiser
Not recommended to put a solid hub on an Alpha. The dog clutch does not like it.
Mbam is offline
Old 05-15-2018 | 07:51 PM
thanks i will pick one up
