Fast fuel injection
Has anyone tried the fast fuel injection system{ 303002rb] its a dual throttle body on a supercharged 557" big block. Looking to get rid of the dominators and switch to fuel injection.
I think you would be farther ahead to use the Holley Injection , FAST doesnt have much in the way of support in the Marine end of things.
I ran the fast efi with msd box it was a nightmare would not buy there stuff again. Go with Holley.
Care to elaborate apache?? I'm also curious about FAST...what was a nightmare?? tuning, performance, customer support?? Would running their dist. tied in with the fuel injection have helped your situation??
The box is sensitive to rf noise and a msd box is not good for that has a lot of RF. I had to have a lot of capacitors to help the problem out even used resistor plugs to help with the problems. Even the pickup for the crank trigger was close to the alternator was a problem. If it had Hall triggers it may of not happened. I am not the only one with these issues. Maybe the newer ones are different but I would stick with a holley and do individual coils or a batch fired coil. Took two weeks to figure out what was going on with it would sit there and just shut off like it hit the revlimiter.
Go with the Holley.
Easy to install and with the help that is available here it is easy to set up. |
do they make a holley kit that can be run in a dual setup on a roots blower?? I thought last I checked there wasn't any roots blower options??
holley does not make a kit to go on a roots blower. any suggestions on wich holley controller to use.
That's what I thought...didn't mean to hijack your thread btw...was just trying to get some clarification for everyone
Just an opinion here. Download the software for the different companies and see which one you want to deal with. None of the systems are as easy as the Salesmen claim. Tuning real time is a plus.
If you want to have two throttle bodies you just need to tie the two throttle arms together. Only one will have the TPS connected. They will need to be synced. If you want to put them on a roots blower couldn't you just install the injectors under the throttle bodies. I have read some people install a couple of injectors under the throttle bodies and then the rest of them in the runners.
| All times are GMT -5. The time now is 05:37 PM. |
