WHere does this ground wire go..hp500 >
Old 05-27-2018 | 09:27 PM
Default WHere does this ground wire go..hp500
Looked at it all day and can’t find where this wire goes. Hp500 w/thunderbolt V carb. It is item 8 on this parts diagram.
https://www.vansoutboardparts.com/me...7,16,1446,5777
Ground wire from the bell house stud to somewhere...that I can’t find. Any help would be appreciated.
Dean
Deanrw3 is offline
Old 05-28-2018 | 04:54 AM
Ayuh,..... To the Ground post(-) on the battery,.....
Bondo is offline
Old 05-28-2018 | 06:17 AM
My battery wires come in on the other side by the starter and ground to a post there. This wire is thin and about 10" long has a smaller eyelet on the end.
Deanrw3 is offline
Old 05-28-2018 | 06:24 AM
Looks like one that goes to the transom plate.
temz is offline
Old 05-28-2018 | 06:31 AM
jeff32's Avatar
I had the same question on my center forward engine in my triple. It is there, unplugged, not long enough to go to transom because the center engine is like what 3-4 feet away from transom? Wire is like 10 inches in fact, so too short to reach batteries on either side, and cant find a small enough bolt to put the wire eye on...
mistery....
but if you do find i will sure read your answer! My boat still runs fine without it meanwhile...
jeff32 is offline
Old 05-28-2018 | 06:35 AM
Negative post on mercathadoth box?
KWright is offline
Old 05-28-2018 | 08:22 AM
Post #4. It goes to the transom plate. Small crew with 5/16 hex head.
sonicss42 is offline
Old 05-28-2018 | 09:12 AM
That is part of the mercathode grounding for all Bravo drives. It goes from the bell housing (battery ground post) to the transom plate. There are others just like it which are different lengths that connect the tiller arm to the transom plate, gimbal ring to bell housing, etc. Standard for stern drives, but not long enough for any other app
AllDodge is offline
Old 05-28-2018 | 10:16 AM
BUP
mercruiser grounds all systems whether you have mercathode or not. Example even the steering arm grounds to the inner transom plate and the transom plate grounds to the back side engine ground stud. The back side engine stud grounds to the neg. side of battery and so on.
his ground lead goes to the back side engine ground stud
for the guy with the center engine ( 3 engines ) the neg lead jumpers to closest inner transom plate of the other engines that is grounded. properly from however most likely from back side engine ground studs.
BUP is offline
