K-plane pump question >
Old 05-29-2018 | 07:57 AM
Default K-plane pump question
I was using the boat over the weekend and one k-plane pump stopped working. I would press the button in either direction and the pump would not turn on. My setup has a "both" button also, when I pressed that, only one pump worked. I went to look two days later and it worked with no issues. Should I worry about it? Could it be the solenoids on the pump? Could they have an issue when it gets hot in the engine compartment? Ground?
FBRONCO is offline
Old 05-30-2018 | 04:47 AM
Ayuh,..... Sounds like corroded wirin' connections to that pump,......
Bondo is offline
Old 05-30-2018 | 07:03 AM
No corrosion at all on the wiring. I'm thinking it could be the motor since it didin't work in the up or down direction. I think it would be hard for both solenoids to be bad?
FBRONCO is offline
Old 05-30-2018 | 08:25 AM
Revelocity's Avatar
1. Do your pump solenoids have a solid 12V on their input side?
2. Check your ground for the motor/solenoids. Where do they terminate? Jump motor/solenoid ground to battery negative to rule out bad ground terminations.
3. If the 12v is going to the pump motor and ground is good - then it's bad motor.
Revelocity is offline
Old 05-30-2018 | 10:31 AM
Thanks for the advice. I'll have to bring my tester and some jumper wire the next time I go out. I usually carry the jumper wire.
FBRONCO is offline
