-   -   worn out B1 HP transom assemblies.... question... (https://www.offshoreonly.com/forums/general-q/354398-worn-out-b1-hp-transom-assemblies-question.html)
eichhoma 06-04-2018 11:58 AM
Can they be rebuilt? are they worth anything worn out?
I have a couple out of a cigarette that had a bad transom and some water got in and put a little rust on the bottom of one of them and a few of the bolts have some corrosion...
they have brand new bellows in them and are complete with inner transom plates, trim cylinders, and have been frankensteined a few years back...
Looking for advice on what to do with these... thanks.
phragle 06-04-2018 04:51 PM
biggest thing..is the pin and ring in decent shape????
eichhoma 06-05-2018 08:00 AM
the pin and ring are good, the only issue these had was that some water got in the lower ends of them from a little transom rot I had going on...
we opted to put in new transom assemblies at the time. I'll get a couple pics uploaded shortly
Panther 06-05-2018 01:18 PM
Should be ok I would think. If the rings are worn, I have have run over-sized pins or you can also get them welded and run a standard pin..
eichhoma 06-06-2018 10:10 AM
Here are some pics of what I have... complete units with trim cylinders, cables, and inner plates....
what would be a fair price to ask for this stuff as it sits? Thanks in advance.https://cimg8.ibsrv.net/gimg/www.off...95ea22f053.jpg
https://cimg9.ibsrv.net/gimg/www.off...364c06d093.jpg
https://cimg0.ibsrv.net/gimg/www.off...25b33a35c0.jpg
https://cimg0.ibsrv.net/gimg/www.off...2589d90e9a.jpg
