Fuel pressure issues 600 SCi ?? >
Old 06-08-2018 | 07:00 AM
Default Fuel pressure issues 600 SCi ??
Hello guys
i am new with my 600sci and not shure if i have an pressure problem or not!
Engine starts,idle and run perfect!
But when turn key on and start not the engine i get error on smartcraft monitor!
Key on ,i get one short beep and fuel pump work 3 seconds! When i start the not the engine then,maybe because proramming the ecomonitor, i get after 30-40 seconds and error on the monitor that say LOW FUEL PRESSURE.
After starting the engine the error is reset and the fuel pressure on the monitor is ok as it must be!
As i am new to the 600,i am not shure if this is normal or my fuel system,or lost pressure in any way!!
Hope i get some help here as some guys use the 600 SCi!
regards.
Michael
Brembofreak is offline
Old 06-08-2018 | 12:25 PM
I have check now again and try to look for fuel pressure with manual gauge!
There is no pressure at only ignition on! not on Smartcraft and not manual gauge!
So smartcraft set the error after 30 seconds without motor running.
Direct when start the engine the pressure comes! looks the backlines will be regulated by underpressure from the intake and all this is normal at the 600 and other blower motors????
michael
