Ignition shutting down when WOT. >
Old 06-10-2018 | 09:24 AM
When it shuts off,it will not start right back up,right?you need to have a volt meter with you and probe the purple wire(its the run wire from the key swittch)
you'll have to work quickly. Good luck these problems such to find
sutphen 30 is offline
Old 06-11-2018 | 05:36 PM
It will not start right back up.
I ordered another alternator. I'm hoping that it's just charging too much.
tnc110 is offline
Old 06-11-2018 | 05:58 PM
F-2 Speedy's Avatar
15.5 volt if I remember correctly ?
where were you seeing this on the amp gauge ? if that correct its to high....should be around 12.8 - 13.2 ? could be over heating a component and failing till it cools off
With the engine running / charging check the voltage at the battery ....see if the auto parts place can test it before you install it
F-2 Speedy is offline
Old 06-11-2018 | 09:14 PM
Yes on gauge. (Volt gauge actually)
tnc110 is offline
Old 06-11-2018 | 10:28 PM
BUP
so no start period ??? If that is the case
test the pick up coil in the distributor -- possible your issue if so buy the merc one -- read the post 502 will not start
BUP is offline
