Will this block work? >
Old 06-13-2018 | 08:54 PM
NMN
Default Will this block work?
The boat I picked up recently ended up having a Gm 5.7 SGI Casting # 1409360 with a cracked block, something I knew might be a possibility. I have found another block but I am unsure if everything is going to match up correctly or if I need to search for a different block? The block ID is V0531TYZ . 1975, 350, 165 HP,4 Bolt. Any help would be great!
NMN is offline
Old 06-15-2018 | 05:01 AM
Ayuh,.... 'n what vintage is this one,..??
Bondo is offline
Old 06-15-2018 | 07:17 AM
NMN
The cracked block is in a 1982 Hammond Challenger MK II. Someone had already done a motor swap long ago
NMN is offline
Old 06-15-2018 | 08:09 AM
Wobble's Avatar
SORE MEMBER
Hell, it's either time for a big block or an LS. Those challengers love power.
Wobble is offline
Old 06-15-2018 | 08:12 AM
the '75 350 block should be a two piece rear main seal and the 5.7 140*** block is probably a one piece seal so the crank wont interchange. the 140*** number is missing a digit from what I can find and the TYZ is a use designation not the casting number of the block itself.
compedgemarine is offline
Old 06-15-2018 | 09:03 AM
SB
you are missing a # with the block in the boat.
Ryan;s had a 23* 383. Went over 80.
SB is offline
Old 06-15-2018 | 09:33 AM
Where are you located ?
29 FOUNTAIN FUN is offline
Old 06-15-2018 | 09:45 AM
Wobble's Avatar
SORE MEMBER
North Minnesota would be my guess.
Wobble is offline
Old 06-15-2018 | 05:25 PM
NMN
I know it would love one but the checkbook isn't ready for that yet. i am trying to stay with the 350 because I am new to this and its easy to work on as well as lots of parts available.
NMN is offline
Old 06-15-2018 | 05:27 PM
NMN
Thanks for the information sorry about the missing number. I found that you are correct.
NMN is offline
