Where to install and discharge water psi dumps >
Old 06-28-2018 | 06:58 PM
Rhythm and Blues's Avatar
Originally Posted by BenPerfected
We dump water from the front of the intake manifold thru the transom with a 90 degree fitting in the intake. The water pressure is controlled by the size of the hole in the reducer to give us 10-15 lbs water pressure
Thanks BenPerfected, appreciate that. I saw you tried to add a pic or something?
Rhythm and Blues is offline
Old 06-28-2018 | 09:40 PM
Tinkerer's Avatar
Because my drive is SO high I don't have a pressure problem but I do have dumps that I use as a drive cooler.
I installed the dumps into the back top of my standoff box with short pipes that direct the water at the sides and top cap of the drive.
I have no overheating signs on the top of my drive.
Tinkerer is offline
