500EFI alarm
if that links to Walker 200 - 1047 that might be it but ??
I can not remember the exact ac delco #
That is the correct Merc number posted and I have those in stock.
https://www.jegs.com/i/Walker-Produc...-1047/10002/-1 possible ?? not sure
and if you look at AC delco 213- 895 will look the same as well. I am Mixed up which one it is exactly cause I only have the merc one.
thru the auto stores --- If I recall correctly One might be for a govern model used in the truck world. They look exactly the same -- govern vs NON govern.
http://www.davesdiscountautoparts.com/catalog-2/itemdetail/acdelco-gm-original-equipment/213-895?gclid=321-445409-gb&gclid=EAIaIQobChMIzc-M-PGN3AIVARxpCh0tKwvCEAYYASABEgIl-_D_BwE
From http://parts-catalog.acdelco.com/cat...tock_check.php
Put in AC delco 213- 895 you get:
(Same vehicles as Walker 200 - 1047)
Vehicle: 1995 Chevrolet K1500 5.7L V8 VIN:K
New Vehicle
Group / Subgroup: Fuel/Emissions / Fuel Inj. Sens, Rly and Switch
New Group / Subgroup :: Smart Search
Back
Next
Parts Matching Your SelectionACDELCO GM ORIGINAL EQUIPMENT
Throttle Position Sensor
Part Number: 213-895
Product Notes:
All; REPLS 17112679)(Exc SEAL; VIN: K*
Per Vehicle: 1; Years: 1992-1995
New Vehicle
Back
Next
Throttle Position SensorPart Number: 213-895
Product Notes:
Just saying I am not sure if it is Walker 200 1047 or which AC delco one it is either. Its either Ac delco 213-894 or 895 for the Merc 500 efi ?
So what does AC delco 213 894 match up to as far as Autos / trucks ?
here are the Acdelco 213-894 vehicles:
https://www.summitracing.com/parts/a...et?prefilter=1
So now I'm not sure the TPS is actually the problem. As I mentioned its very erractic but once I get past idle the issue goes away. I have no problems getting on plane and running 4000+ rpms. I would think if it were the TPS I'd have issues throughout the rpm range and not just at idle?
^^^That is incorrect.^^^
A TPS is just like a rheostat...it has a wiper that wipes across a circuit to change the voltage. So, you can have a deadspot.
However, since you are not checking the tps readings...how do we know ? We don't.
Kind of odd i am spending this time on trying to find the AcDelco TPS for this since you don't know.
Anyway, will be good info for my and other's parts database.
Can you, or someone else, or BUP (since you have a Merc one on the shelf) if the rotor on the TPS rotates clockwise or counterclockwise as the throttle is opened.
I'm back to investigative mode.....was only able to spend some time as i was boating most of last week thru last night.
