Batt Voltage 1 Volt Lower at Dash Normal?? >
Old 07-14-2018 | 08:27 AM
Rage's Avatar
I am thinking of inserting a relay between the ignition switch switched power feed out and the circuits that it powers using power from the fuse panel as it's power source to power those circuits. I assume that the kill switch and the neutral switch will still work which I will need to confirm. Anything that I am not aware of that would be a problem with this approach?
Rage is offline
