Blower on the gen V 330 454? >
Old 07-10-2018, 01:52 PM
Default Blower on the gen V 330 454?
Looking to add a bit more hp to my cruiser. I know the cast components aren’t the greatest, but I have a fresh long block in the boat and like it’s overall performance. Just looking for a little better acceleration and maybe a little top end Hp.
I was thinking blower as it won’t tremendously affect the torque curve or low rpm control.
I would be happy hitting 400-420hp if possible on low boost.
Is is there any reason I should stay away from going this route?
The boat it’s going in is a 27’ Chris craft with a Volvo 290 dp ( the other reason I don’t want to go crazy since I’ve heard mixed opinions on their strength)
thanks in advance
Tani1500 is offline
Old 07-10-2018, 09:13 PM
Received 1,491 Likes on 806 Posts
Some do it and have no issues however I'd never do it it especially on a marine engine. Short burst on the street might risk it with knowing the consequences. Blowers build a lot of heat and typically engine is much happier with forged blower pistons along with forged crank. There's a lot of stress on crank snout with a blower as well. Think of what your really gonna gain. What model 27 do you have. Personally I wouldn't do it.
getrdunn is offline
Old 07-10-2018, 10:22 PM
[/QUOTE]
concept.
Tani1500 is offline
Old 07-12-2018, 09:25 AM
Anyone else have any input on this? I have a lead on a blower setup for a good price.
Not looking to push this thing past 5k rpm and maybe run 3-4 psi at most.
Tani1500 is offline
Old 07-12-2018, 02:18 PM
Getrdunn answered as well as anyone else could. Putting a blower on cast internals in a boat isn’t likely to find any support here as even forged internals are problematic enough. Don’t forget that you’d most likely have to replace your tank pickup, upsize fuel lines, upgrade the oil system etc. Unless you do a blower build from scratch with all of the properly sized rigging and tid bits a lot of nagging little issues can ruin your season.
Baja Rooster is offline
Old 07-12-2018, 02:43 PM
SB
Received 3,116 Likes on 1,403 Posts
Should hold up to 400HP of Nitrous too, in case anyone wants an answer I would not say okay to also.
SB is offline
Old 07-12-2018, 05:02 PM
GPM
thanks in advance
I love the superchargers, but they don't mix with cast pistons, even low boost will crack the ring lands off if you detonate a couple times.
GPM is offline
Old 07-12-2018, 08:23 PM
Rookie's Avatar
Received 1,207 Likes on 580 Posts
In good conscience nobody is going to tell you to go ahead and do it. Cast pistons and boost are like oil and water, they don't mix.
Rookie is offline
Old 07-13-2018, 07:14 AM
Thanks guys, that’s what I figured, so ill just run it as is.
Tani1500 is offline
Old 07-13-2018, 07:25 AM
For what you would spend for the blower, good heads intake carb etc will get you close to the same...there are 4,357,892,253 different threads on here about build up a 330 hp 454
phragle is offline
