Msd distributes bushings? >
Old 07-13-2018 | 05:02 PM
Default Msd distributor advance stop bushings
Can anyone tell me the sizes of the advance stop bushings on an msd distributor ? I can’t tell what color it is because it’s a little rusty. Also , what spark plugs would you use on a 454 with B&m 250’s? Got this old project boat almost ready,,,,
Scscoripion is offline
Old 07-13-2018 | 05:07 PM
My bushings are .430
Old 07-14-2018 | 01:06 AM
Assuming BBC rect port heads, I would run AC MR41T plugs.
Griff is offline
Old 07-14-2018 | 07:59 AM
Thanks for the reply, I will try them. Any idea on the distributor bushings? I took my msd apart yesterday,trying to figure out the timing curve.
Old 07-14-2018 | 08:06 AM
Also, yes they are bbc rectangle heads, were mercury 400,s , now mabey 550 h.p.?
Old 07-14-2018 | 01:23 PM
The kit should have all the specs https://www.summitracing.com/parts/msd-8464
Griff is offline
Old 07-14-2018 | 10:20 PM
Thank you Griff, I’m going to look at it, I checked my plugs, they are NGK # 7
Old 07-14-2018 | 11:59 PM
Those are probably close. The NGK 7 is equivalent to and AC 42 heat range.and an NGK 8 is equivalent to an AC 41.
Stock NA Merc engines run an AC MR43T or NGK BR6FS. Merc 525SC/600SC run an AC MR41T
Griff is offline
Old 07-15-2018 | 08:53 AM
TomFTM's Avatar
I will let u know tomorrow about the bushing sizes, working on msd distubuter tomorrow and I have all the bushings.
TomFTM is offline
Old 07-15-2018 | 08:45 PM
That’s good ! Do you have any idea what curve I should run with 8.6 compression,B& m 250’s , 1000 cfm Holly’s, stainless marine headers, 24 pitch 4 blade Cleavers?
