Intake, dominator and headers will all help! A tunnel ram even more so. If you can do dry pipes you could get aggressive with the cam and really wake it up. |
Would you go 4500 intake and carb or 4150 intake with 4500 carb seems to be some discussions on that as well
You wont see any measurable gain going from qf 1050 to a dominator. I tested them back to back on a 660-685 hp bbc on dyno, zip, zilch. As far as intake, add a 1" open spacer and 1" blended 4 hole spacer on top of that or similar if you havent already and have room. Recently did this on a 555 on dyno, it picked up over 20 hp and similar tq. Exhaust, buy best exhaust you can afford, Smitty
Thanks for the input, what intake where you running just curious sounds,like the victor jr is better than stock dart single plane
Originally Posted by Jamsf1984
(Post 4638224)
Ohhh dam went down after pv removal way lean, do you generally try to run pv on marine build or remove i know with street car we try to keep them, also do you know about where ballpark jetting would be on a setup like mine with that q1000 qf carb, im gonna pull mine tonight and look i think it was stock jetting but we will see thanks
Looks like stock jetting is 82p 88s and 4.5 pv in front
Also im running a 25p mirage plus how do you feel about a bravo 1 instead on the bajas
(Post 4638323)
| All times are GMT -5. The time now is 04:19 PM. |
