Trying to find replacement water hose
https://www.marineengineparts.com/me...90859-hose-kit
http://www.glmmarine.com/pdf/Instru-47230.pdf
Dont need the whole kit just the hose. Listed as GLM-47160 but I cant seem to find that or equivalent listed anywhere for sale. I tried pushing it in and the hard tube dented in, I dont trust it to not develop a crack
Aftermarket Marine. You can also get it on Amazon, same price. Claim it will permanently cure the problem.
https://amarketparts.com/products/654
diameter is small from them -- internally on the end. reduced water flow.
Salt water usage is mainly the issue that causes the restriction. If you are in fresh water that is not needed anyways.
Most likely better off with 32-8M0090859 - Hose Kit This kit has everything you need, including the installation tool that you will need. List $ 60 and it is still available.
