-   -   Fuel line removal tool? (https://www.offshoreonly.com/forums/general-q/355574-fuel-line-removal-tool.html)
chevy57 07-24-2018 07:06 PM
folks,
my my boat is 3 hours away and not running right. I'm planning to test fuel pressure and clean filters of the fuel pumps etc. I just got the service manual for my 2003 gen 2 cool fuel system. The manual references a fuel line to fuel rail removal tool. What is this tool and where can I get one?
​​​​​​​Kevin
Griff 07-25-2018 01:28 AM
Google fuel line removal tool. There are lots of different kinds, but they pretty much all do the same thing.
chevy57 07-25-2018 05:30 AM
I already googled it. Unfortunately the boat is 3 hours away so I can't look at it to see what type of lines are on the boat. I am trying to have all the tools I need with me. Does anyone know the tool required for a 2003 496 Mag? It's a gen 2 cool fuel system if that matters.
​​​​​​​Kevin
AllDodge 07-25-2018 08:12 AM
Always best to provide serial number
BUP is the guy to ask, or another which has removed, but it says to find locally so my assumption would be the regular auto type. I don't have the master kit but just have the white things on top and they have worked fine when needed
https://www.autozone.com/test-scan-a...set/291413_0_0
Sydwayz 07-25-2018 08:41 AM
Agree, just buy this from Advance Auto or the like.
Ryan00TJ 07-25-2018 08:57 AM
Yep, Autozone might rent one also. The female fuel line has little fingers, similar to a chinese finger trap. These lock onto the male barb of the fuel rail inlet. The tool slides over fuel rail and pushes into the female hose and unlocks the fingers.
Tip.... before disconnecting fuel line from rail, bleed pressure from schrader valve on fuel rail near the coolant expansion tank. Place a few rags under valve when doing this. Same for fuel hose to rail.
chevy57 07-25-2018 09:53 AM
Serial number 0M383059
AllDodge 07-25-2018 10:38 AM
Thanks, you have first gen 496 so it doesn't have the boost pump.
chevy57 07-25-2018 12:58 PM
That is interesting. I thought there were still 2 pumps. It was my understanding that there is a booster pump above the fiuel separator and a high pressure pump on the opposite side. Cool fuel gen 2
Knot 4 Me 07-25-2018 01:01 PM
Your '03 will have the boost pump mounted by the spin on fuel filter and raw water pump.
