Supercharged 565 detune for pump fuel question >
Old 07-27-2018 | 09:13 PM
FASTERDAMITT's Avatar
Default Supercharged 565 detune for pump fuel question
So I am looking at a boat with a 565 Chevy with a blowershop supercharger and intercooler. Sorry I don't have the specs yet, but hopefully soon. My general question is, he says he has to run race fuel at 7 # boost as is. He is not the original owner of the build so I .second guess his information. If he is correct, of I reduced the boost to say 4 or 5 #'s does it sound logical I could possibly run pump gas with the correct tune?
FASTERDAMITT is offline
Old 07-28-2018 | 01:00 AM
I'm surprised he has to run it with anything more than 93 octane as is. A lot depends on the static compression ratio though.
Griff is offline
Old 07-28-2018 | 07:15 AM
articfriends's Avatar
Alot of unknown variables there. Base compression? Iron heads?
articfriends is offline
Old 08-03-2018 | 08:55 PM
Finally received the specs.
Old 08-03-2018 | 09:00 PM
Camshaft. Aluminum heads. I will have to do a comp test prior to buying...
Old 08-03-2018 | 09:19 PM
Tinkerer's Avatar
You could always tune it for E85.
I also think that 93 octane should be good.
My 598 is set up for an M4 Procharger with 8.6 to 1 static compression. I don't have to run more than 93 when I add the M4.
Tinkerer is offline
Old 08-03-2018 | 09:58 PM
Just as I think.
