Originally Posted by eichhoma
(Post 4642518)
Does anyone think there is any good logic in the Blaster coil effecting the tach, or somehow causing some interference?
thanks for the additional info.... I appreciate the help, this might quickly get out of my comfort zone but we'll give it a shot
Originally Posted by payuppsucker
(Post 4642527)
^^^^^^^^^^^what Steve (SB) said................and check the ground wire on the tach and make sure it's secure then trace it to it's grounding point and check that connection. Sounds like a ground issue since actuating any switch causes it to peg out.
(Post 4642525)
I tried running some new msd coils on stock Mercury ignitions, they started to over heat the timing modules to the point that the distributor was double firing the engine @ 10* and again @ 270*................ they are a POS....
But yeh,best bet is to stay away from MSD anything. ;( Many Suck Donkeys ...lol |
Originally Posted by SB
(Post 4642535)
What Paul (payuppsucker) said. :bunnydance: :stooges:
You didn't get the joke. I tried also with the emoticons. LOL.
My name is Scott,not Steve. :) |
My first thought was that I had messed your name up but then I was like "nah".........I'm a dumbass.
I don't care really what I'm called. Was trying to make a funny. LOL.Just don't call me Darr, Sunkin, or KidApache. :)
(Post 4642538)
That sucks. Don't quote me but i think the stock merc canister coil is .8 ohms and this must be matched when using a different coil ? That said, before I heard this, I had installed the HVC epoxy canister coils on several TBIV motors many years ago (10+) and still going strong.
(Post 4642518)
Try running a ground wire from one of the dist cap screws to a good clean ground on the engine block. |
| All times are GMT -5. The time now is 12:58 AM. |
