spastic tachometer.... >
Old 08-08-2018 | 12:41 PM
Originally Posted by eichhoma
Does anyone think there is any good logic in the Blaster coil effecting the tach, or somehow causing some interference?
No
payuppsucker is offline
Old 08-08-2018 | 12:45 PM
thanks for the additional info.... I appreciate the help, this might quickly get out of my comfort zone but we'll give it a shot
eichhoma is offline
Old 08-08-2018 | 01:08 PM
SB
Originally Posted by payuppsucker
^^^^^^^^^^^what Steve (SB) said................and check the ground wire on the tach and make sure it's secure then trace it to it's grounding point and check that connection. Sounds like a ground issue since actuating any switch causes it to peg out.
What Paul (payuppsucker) said.
SB is offline
Old 08-08-2018 | 01:13 PM
SB
I tried running some new msd coils on stock Mercury ignitions, they started to over heat the timing modules to the point that the distributor was double firing the engine @ 10* and again @ 270*................ they are a POS....
That sucks. Don't quote me but i think the stock merc canister coil is .8 ohms and this must be matched when using a different coil ? That said, before I heard this, I had installed the HVC epoxy canister coils on several TBIV motors many years ago (10+) and still going strong.
But yeh,best bet is to stay away from MSD anything. ;(
Many Suck Donkeys ...lol
SB is offline
Old 08-08-2018 | 01:15 PM
Yea but it's Kelly, not Paul :-(
Old 08-08-2018 | 01:17 PM
SB
You didn't get the joke. I tried also with the emoticons. LOL.
My name is Scott,not Steve.
SB is offline
Old 08-08-2018 | 01:29 PM
My first thought was that I had messed your name up but then I was like "nah".........I'm a dumbass.
Old 08-08-2018 | 01:33 PM
SB
I don't care really what I'm called. Was trying to make a funny. LOL.Just don't call me Darr, Sunkin, or KidApache.
SB is offline
Old 08-08-2018 | 01:49 PM
F-2 Speedy's Avatar
agree, my name is Nobody not Shirley or Sue......
F-2 Speedy is offline
Old 08-08-2018 | 10:30 PM
Very doubtful. My bet is on a ground issue.
Try running a ground wire from one of the dist cap screws to a good clean ground on the engine block.
Griff is offline
