High Idle - Regardless of Carb Adjustment
Long story short, mainly the port side motor has a high idle in neutral. Both do it now, but happens most frequently/all the time with the port side. In gear, it's perfect, but after cruising/running, the idle jumps up from ~750-800 in gear, to ~1100-1200 in neutral. I have adjusted the idle screw on the carb but that seems to only effect the idle while in gear. I don't want to damage the drives.
This seems to have been brought on by timing my motors at full advance. It's a semi built 502 MAG with Holley 800CFM carb. Timing at 36 all in, with TBIV-22 modules, which puts it ~14 degrees at idle. Im running 93 octane. Any recommendations? |
Any chance of a vacuum leak
air leak was my thought
At what rpm are you setting the base timing ? and at what rpm are you seeing full advance on the light
More advance at idlle will typically raise your idle speed You will not be able to lower the idle speed without re-adusting your cable length too. so, remove cable Do all your idle and mixture screw adustments. then adust length of cable so it slides right on without opening the throttles on it's own.
(Post 4643902)
This is from last night while coming in, still in gear: https://i.imgur.com/Zw7fNFx.jpg The throttle cable is adjusted properly. Really the only thing I changed was the timing. |
https://cimg7.ibsrv.net/gimg/www.off...95acc7dd23.jpg
@ 1200 rpms your module could be adding as much as 3 - 3.5 * of timing..........post a pic of the module, is it V8-22 According to this chart there are two different ones |
When you adjusted the idle screw did you also adjust the throttle linkage? If not you can unscrew the idle screw with no affect because the linkage is still holding it forward.
(Post 4644225)
Originally Posted by f_inscreenname
(Post 4644240)
| All times are GMT -5. The time now is 11:46 PM. |
