244/236? You sure its not 236/244? I doubt you have reversion with it dry that far out. Something is leaking inside the engine.
Head gasket, intake gasket, cracked block....etc... My cam is a 230/244 112 LSA (small block chevy) with over an hour of idle time in the driveway, no reversion, oil is crystal clear, with stock manifolds, spacers, and risers. I am beginning to think a lot of the cam reversion issues I read about that had me scared to pick "too big a cam" are due to other issues. |
Are you seeing a full milkshake with water in the oil filter or just a little sludge under the valve cover? |
Originally Posted by Baja Rooster
(Post 4645869)
Originally Posted by Paxtonspeed
(Post 4645867)
Originally Posted by axm0z5h
(Post 4645866)
I just had dry tails built and i was told by pretty much everyone you cannot run flappers with dry tails. instead i had 2 reversion rings put in and 14" tall risers
you have a ve a picture of the reversion rings ? |
Originally Posted by Bulitz
(Post 4645905)
you have a ve a picture of the reversion rings ? Cylinder 1 |
(Post 4645909)
Cylinder 3 https://cimg4.ibsrv.net/gimg/www.off...1d5cd7f3e5.png Cylinder 5 https://cimg5.ibsrv.net/gimg/www.off...0ff956016d.png Cylinder 7 |
(Post 4645902)
no just some in the top cover |
What is the cam LSA? I always put a small bead of rtv on both sides of the water jackets on the intake gaskets just for a little extra precaution. |
| All times are GMT -5. The time now is 11:25 PM. |
