Intermittent fuel pump on mpi >
Old 09-27-2018 | 07:18 PM
Default Intermittent fuel pump on mpi
My port engine is not firing the fuel pump when I turn on the ignition intermittently. The engine cranks but won’t start when this happens. When it does fire the pump, it starts and runs fine. Anyone here have a similar experience? Wondering what the fix might be- relay or new pump? Any tips would be appreciated it’s an 02 454 mag Mercruiser. Thanks!
8myl is offline
Old 09-27-2018 | 07:24 PM
BUP
would have to post your engine serial number one reason Mercruiser did not have any new 454 in 2002. The 6,2 - 377 and the 8..1 - 496 - replaced it in 2001 along with the 502 --- ( black production side ) .
BUP is offline
Old 09-27-2018 | 10:12 PM
try swaping the relays and see if the problem follows the relay. if not check all your connection s from the key switch back.
freekazoid is offline
Old 09-28-2018 | 01:11 AM
Check voltage at pump and then check voltage in and out of relay.
You'll have to check it when the problem is happening
Griff is offline
Old 09-28-2018 | 06:36 AM
pull the fuel pump relay and look at the spade lugs of the connector,,see if they are over heated,also look at the bottom of the relay.merc went from thin pins to wider pins.
sutphen 30 is offline
Old 09-28-2018 | 06:47 AM
I just had this issue on my 502 MPI. Marina replaced the main power relay ($40 - easy to get to on top of the motor). Thought that fixed it until I took it out - hit a good sized cruiser wake and motor shut off. Turns out if was a 10 or 15 amp fuse (forget which) that had a fractional break in it (fuse was in the same area as the main power relay). Both items are super easy to check.
louisa6 is offline
Old 09-28-2018 | 08:18 AM
Default Fuse
yes definitely check fuse my friend had same problem fuse look ok but had a fine crack bridged by corrosion .
paul buckner is offline
Old 10-02-2018 | 12:33 PM
Check fuse holder also for corrosion and tightness of the fuse itself in the holder. Also check the power wires into the VST if you have one as well as the harness connector for it. If it winds up being the fuel pump in the VST, sourcing one here is much less expensive than OE the last time I looked ($80) https://speedncustommarine.com/
Tractionless is offline
