Dimple rods
Old 10-23-2018 | 12:31 PM
F-2 Speedy's Avatar
I wouldn't mix rods, weight could be several grams different
F-2 Speedy is offline
Old 10-23-2018 | 01:08 PM
that's what I was thinking. didn't want to mix them up. I cant seem to find them anywhere though....I called my local gm dealer and he didn't really know crap. said he could get a rod for 7.4 which I believe is the same but didn't have a picture to tell me if its a dimple rod or not. are the dimple rods a factory thing or??
chopperkell is offline
Old 10-23-2018 | 02:39 PM
Originally Posted by chopperkell
thank you. I looked up that part number and it is a big block chevy rod but doesnt look like its a “dimple rod”. Mine have a little bump towards the too which i found out means its a dimple rod. Is that going to matter? Using one disfferent rod?
What size rod bolts ? How old is your engine ? I have used that rod several times in the last two years to replace 502 rods and as far as I remember it was identical.
I just looked in my 0ld 2005 GM book and I think the rod you want is 10198922 but I dont think it is available anymore unless you can find someone that has one on E-bay etc. Jegs says they can ship it but Summit says not available. More than likely the other number is the replacement.
https://www.jegs.com/i/Chevrolet-Per...98922/10002/-1
BillK is offline
Old 10-23-2018 | 02:41 PM
10170198 replaces the 10198922
https://paceperformance.com/i-625500...cting-rod.html
BillK is offline
Old 10-23-2018 | 05:40 PM
Yes the 10198922 is what I have now. I see the discontinued them. the replacement looks a little different though. think its ok to replace just one rod with the new style? any kind of weight issues?
my rod bolts now are 7/16" and when I ran the numbers on the motor it came up as 96+ gen 6 I believe.
Old 10-23-2018 | 05:49 PM
BBYSTWY's Avatar
I've got a complete set out of my running 525sc with the pistons still attached...I'm make you a deal on all of them if you're interested PM me
BBYSTWY is offline
Old 10-23-2018 | 05:55 PM
GPM
I believe the GM rods are made in China now, if you're going that route you might want to look at the Scat 4340,
GPM is offline
Old 10-23-2018 | 06:27 PM
pm me your address,i have plenty of good takeouts.i will send one usps,just send me whatever it cost to ship it to you.add in,i believe teague sells new takeouts for 25 bucks each if you are worried about useing a used one.
mike tkach is offline
Old 10-24-2018 | 09:55 AM
Call Ron Sporl he's got some laying around..........Sporl Marine
I bought a set of 8 rods and pistons from him for 2 bones. Only used 2 of them so i have a few good take out rod and piston complete assy if needed also
92nsx is offline
Old 10-24-2018 | 05:00 PM
rod is on it,s way,usps tracking#9505512839968297232793.merry christmas.
