Bravo one xz  left or right? >
Old 11-13-2018 | 05:41 PM
Default Bravo one xz left or right?
hi guys , i think this is a easy question!
i have a bravo one xz, i m having isues setting up the right prop , rifght now i m using a mirage plus 25P
engine is jut getting 4200rpm. So i gonna trywhit a mirage plus 23P
the prop i found is a left rotation, i m sure bravos can turn right and left props, just need to change the cable position right? Or shift in reverse!!! Can i use a left prop right?? Whit no problems?
I dont wanna cause any demage to my new bravo xz!
thanks for the help!
MIAMI/BAJA is offline
Old 11-13-2018 | 08:08 PM
Yes, it’s just as simple as a cable position swap
JaayTeee is offline
Old 11-13-2018 | 08:49 PM
The correct factory prop is a RH 23 Mirage Plus.
Yes, XZ's or any Bravo style drive can spin either way. Just need to swap cable at the shifter or test it by running the shifter in reverse.
Griff is offline
Old 11-14-2018 | 12:51 PM
Default Thanks a lot
thanks ,i ll try this prop this weed end.
Old 11-14-2018 | 08:58 PM
Tinkerer's Avatar
On my Scarab I used to rotate the drives every year.
Tinkerer is offline
