Holley EFI system. I want to use a Dual Sync distributor for SEFI.
Holley EFI system. I want to use a Dual Sync distributor for SEFI. I dont know if these are approved. Is there any other option. I need the dual sync to have cam sensor and crank sensors built in .
"sequential port injection. Holley HP" Yes that it.
https://www.holley.com/products/fuel...arts/565-207BK
It looks not to be Marine approved.
you may want to look into a hall effect crank trigger on the front of the motor. It is crank mounted and a larger diameter for precise measurement of the crank position.
Started with the Accel dual sync roughly 16 years ago, not the best product but the only one at the time, run the Fast dual sync now for 8 or 10 years, very similar to the MSD / Holley, works great.
