Read my plugs please
#31
one O2 senser on each bank is just an average of AFRs. He could have one cyc rich and one lean and so on. This is also an indication of the plugs showing rich and lean conditions.
I understand this is a carb engine but will add for whomever
efi engine fuel injectors flow rates and spray patterns play in the mix if the set of 8 plus if they are not balanced as close to possible across the board. This really holds true for used sets of fuel injectors and in many cases are commonly missed when one rebuilds their efi engine(s). That will cause rich and lean conditions alone. Just posting added info
#32
That does not invalidate the O2 readings. Cars have had one O2 sensor per bank for years and give vital information, much more so than reading a plug. True balanced injectors are beneficial, but in this case we aren't saying one cylinder is at 17 and the others at 11.5. That just doesn't happen even with a carb. I will take the AFR readings over plugs any day assuming all else is working properly.
#33
The AFR will tell you nothing as to detonation and heat in cylinders, this requires Plug reading (or pyrometers).
So, in my mind the two work together to give a more informed analysis of the motor health and tune.
#35
On my tests, cylinders 145and 8 look very different than the rest. 236 and 7 are leaner usually and the tune is about getting these four holes to burn in the safe zone. Others may have different results with various intakes ,injection, porting and so on. Plug reading is a sure bet to check each cylinder, because it only takes one to break up the party. AFR’s are great info but don’t tell the whole story every time. I think Glenamy just said this. Sorry for the repetition
#36
Thanks everyone for the feedback and advice.
I thoroughly scoped each cylinder and all pistons looks good, no damage, cylinder walls look good too, I also did a compression and leak-down test and compression looks good and leak-down shows each cylinder within 2% of each other.
I reinstalled new Autolite 3924's and my plan of attack is to lower timing to 30deg (from 34deg) and take the boat for some runs to record the afr's. Then re-jet accordingly to get th afr's down etc. Then hopefully do some plug reading runs.
Thanks again
Thanks again
#39
Thanks again
Thanks again
