-   -   311 Bravo x dimension (https://www.offshoreonly.com/forums/general-q/358441-311-bravo-x-dimension.html)
Mohawk242 01-04-2019 07:09 PM
Does anyone have the x dimension for a Formula 311 with bravo drives? Or I would take a vertical dimension from the bottom of the transom assembly if someone has access to a boat.
endeavour32 01-04-2019 11:21 PM
My SR-1 292 which is basically the same boat, the prop shaft was 7" below the hull. I ended up running its boxes with -3 IMCO's. Getting it to plane off with bravo 4 blades took a little work, but once up, it ran well. I think a great set up on a budget would be to run -2 IMCOs without any boxes.
Mohawk242 01-05-2019 05:57 PM
Thanks for the information. I am replacing the transom so figured I should just swap over to bravo drives. I have struggled finding a good starting point with any other forums. Especially Facebook pages.
endeavour32 01-09-2019 10:00 PM
7" is too deep, I would put them at 6" or 5 1/2", 5" without boxes may work, but I'm confident you would have no issues getting on plane at 5.5" with bravo props.
IGetWet 01-10-2019 08:29 AM
Go high like endeavor32 says, maybe even 4 to 4.5” above the bottom, or 17.875” to 17.375” X-dimension. You can ad spacers to standard bravo lowers. Bigger tabs also help planning too.
Mr Maine 01-12-2019 09:06 PM
So stock they are 7 inches below, your saying 4.5 inches above, so raise them basically a foot??
Seems like a lot haha
IGetWet 01-13-2019 10:20 AM
Lol yea you got it. Build the transom up so its like a wall in the back you have to climb over.
No, not above, 4-4.5 below the bottom. My mis-type.
