Gen 6 seawater/fuel pump combo >
Old 01-16-2019 | 06:00 PM
Default Gen 6 seawater/fuel pump combo
Ok so we all know this is a horrible design. Fuel leaking into oil and whatnot. The gen 6 block has the block off. Has anyone put a regular mechanical on and then just blocked off the sea pump? Seems that would eliminate some hassle.
Crude Intentions is offline
Old 01-16-2019 | 07:09 PM
I think the problem is no eccentric for the pump on a gen 6 cam shaft. But a quality electric pump and bypass regulator is an option.
ph1971 is offline
Old 01-16-2019 | 07:36 PM
I put in a new cams and ditched the combo pump. Ran pumps from Mark IV design, no fuel pump provision.
1BIGJIM is offline
Old 01-16-2019 | 07:37 PM
I was wondering that. I would think some do or why put the provision in the block. Can’t rememeber if mine did or not.
Old 01-17-2019 | 06:09 PM
The way I've done it was to remove the fuel pump and rod, use a blank plate where the pump mounts and use a carter electric fuel pump job done ✅
Camalot is offline
Old 01-18-2019 | 02:30 PM
my gen 6 does not have a block off
fastenuff2 is offline
Old 01-18-2019 | 03:12 PM
I have two basically new Carter mech pumps that pump 110gph at 8psi, but I think that your looking for something bigger.
Baja Rooster is offline
Old 01-19-2019 | 09:52 AM
most all of the std gen VI blocks have no block off, made for elec pump only, they started selling replacement blocks and engines thru GM performance that did have a fuel pump mount on them.
ezstriper is offline
Old 01-19-2019 | 02:36 PM
My gen 6 has the provision for mechanical pumps. Just don’t rememeber if my cams had the lobe for it. If they do I think I’m gonna go this route. Put mechanicals back on the block and block off sea pumps.
Old 01-21-2019 | 03:31 PM
Just like Camalot said. Carter electric and away ya go. Been running that way with Gen 6 for 10 plus years
64294501 is offline
