LS Build: In Progress >
Old 05-02-2019 | 06:53 PM
  #271
Originally Posted by MILD THUNDER
One thing about the stock, car engines, is they have an engine management system. My 6.4L hemi is 10.9:1 stock. It also is very sensitive to octane, air temperature, fuel mixture etc. Could see some short term knock retard just from going from one gas stations 93 to another brand. It runs great, thanks to a modern engine management system that as many failsafes working nonstop to prevent detonation. Basically, they run it on the edge from the factory , and "tuning" doesnt do a whole lot for them. The engines run near peak performance thanks to all those sensors.
That beIng said, prob not where id want to be with a carburetor setup and basic ignition setup. I don't think 11:1 compression is "mild" by any means, for a pump gas boat engine. Id say its a bit closer to borderline , and a bad tank of gas away from knocking itself to death. LS or not, detonation doesnt care what you name the engine. Id keep a close on that tune . What kind of egts were you seeing from cyl to cyl?
Carb motors can usually take more timing. Already put a safety net in before coming off dyno Max run was 32 backed out to 29. Also implemented a fail safe for water temp to reduce timing in the event of clog or impeller loss.
mggdoors is offline
Old 05-02-2019 | 06:55 PM
  #272
mggdoors is offline
Old 05-02-2019 | 06:58 PM
  #273
Originally Posted by mggdoors
Good guess. I would say that I am pretty much at the limit of stock ls3 heads on a 4.030 bore as far as hp goes, maybe a few more if I wasnt running marine application. Valve shrouding is hurting me so the only thing left to do is porting. I am done playing around with them for the summer and am going boating. At the end of the season, mid november lol, gotta love Arizona, I will be doing cnc heads and roller rockers. Results will be posted again.
just for the hell of it,go to post#4.
mike tkach is offline
Old 05-02-2019 | 07:01 PM
  #274
Lol. Touche
mggdoors is offline
Old 05-03-2019 | 10:39 AM
  #275
Here is a 468 blower motor on the same dyno just for comparison sake. You can decide if it is greedy or not. I believe he said this was 731 cam
mggdoors is offline
Old 05-03-2019 | 11:07 AM
  #276
Maybe they’ll be faster than 525s
hogie roll is offline
Old 05-03-2019 | 11:17 AM
  #277
SB
Show the part of your sheets that shows fuel flow and I will answer this for you.
SB is offline
Old 05-03-2019 | 11:20 AM
  #278
right about what a stock 525sc merc makes with a cam upgrade...
MILD THUNDER is offline
Old 05-03-2019 | 12:13 PM
  #279
Im sure they will considering I have the ability to rev it if I choose to
mggdoors is offline
Old 05-03-2019 | 12:18 PM
  #280
This is all I have on these.
mggdoors is offline
