Found light cylinder scuff during upgrade >
Old 01-23-2019 | 06:54 PM
Heat. To lean, Higher compression need to run cooler. Air pockets. Not enough water pressure
veloc410 is offline
Old 01-23-2019 | 07:24 PM
Tinkerer's Avatar
If these were automotive bottom ends and You plan on putting a blower on it the bottom end should be taken apart and clearanced for marine high HP.
I bet you are going to find that the pistons are tight.
Spend the $ now OR spend the $$$ after it blows up.
Doing it right and bullet proof the first time is CHEAP.
BTDT
Tinkerer is offline
Old 01-23-2019 | 07:48 PM
Originally Posted by rob vanharten
Guys I found this light scuff taking one of my heads of last night. You cannot feel it with your finger but if you drag a finger nail on it you can just barely feel some light rumbles. These are GM ZZ572 crate motor bottom ends that have never been apart. They probably have 125-130 hours on them. Engine never burned any oil or smoked. I was hoping not to have to get into the bottom ends. What do you guys think??
that will hone out easily. .0005 bore will be ok
veloc410 is offline
Old 01-23-2019 | 08:55 PM
any other markings in the other bores ?
Ya, actually I have been looking closer at the other cylinders and most of them have some very light scuffing at the north and south edges of the cylinders and some have light marks at all four corners. When I first bought this boat the timing was set to all in at 50 degrees. I caught it and fixed the timing issue, but with what Dan posted earlier wonder if to much timing caused these scuffs....?
rob vanharten is offline
Old 01-23-2019 | 09:02 PM
50. Wow. Probably. 5 & 7 also run leaner, 7 being leanest. Those will show more. Run a jet bigger than rest in that corner . These guys know
veloc410 is offline
Old 01-23-2019 | 09:22 PM
14 apache's Avatar
Running closed loop bad tuneup. Expensive day.
14 apache is offline
Old 01-24-2019 | 11:14 AM
16 Apache whoa buddy , that don`t look so good. lol
ICDEDPPL is offline
Old 01-24-2019 | 11:21 AM
14 apache's Avatar
Lol one day I wanted to cry lol. Only had about five hours on motors. Start of a poker run motors where cold had no corrections from close loop yet and was a cold day. Finished a cooler of beer on the way home on the other engine.
Old 01-24-2019 | 03:47 PM
Talked with my local machinest this morning and I am bring him both short blocks. He will be doing final disassembly and inspection. Check the cranks, upgrade rod bolts and reman rods, hone cylinders with torque plate, new rings, new rod bearings, new crank bearings, and new cam bearings. They will wash block and reassemble short block with the appropriate clearances for a supercharged marine application. Little more money than I had expected to spend on this upgrade but I think it’s money very well spent for peace of mind!!!
Old 01-24-2019 | 08:57 PM
That sounds like a proper plan, and much much cheaper in the long run.
I believe that youd want a little more clearance on the piston to wall anyways, right?
Baja Rooster is offline
