Most HP out of a 525 >
Old 04-04-2019 | 11:15 AM
Originally Posted by MDG_Jason
We found really good gains with the 525 just by going to a big bore. With no other modifications other than a 4.600 bore and ECM tuning to correct air/fuel we picked up approximately 60hp over a stock 525. Final number on the dyno was 610hp. Stock 525s constantly make 550hp on our dyno. By no means claiming to be the highest number from a 525 but we were very happy with the gains
Are 525 blocks good for the 4.6” bore? Maybe it was Mike Tkach saying some are different.
hogie roll is offline
Old 04-04-2019 | 06:31 PM
We prefer and in this case used Dart blocks for these but have gone 4.600 many times on a stock block without problems. Currently doing a set right now for my personal boat which started life out as a pair of 500efis. Block should be magnafluxed if going to 4.600. The Dart block has room to go larger so there is a rebuild left. The stock block is definitey done at 4.600
MDG_Jason is offline
Old 04-04-2019 | 06:45 PM
F-2 Speedy's Avatar
gen 6 502 block should be safe to 4.500 without issue, perfect for a 540....4.25 x 6,385 x 4.500
F-2 Speedy is offline
Old 04-04-2019 | 09:14 PM
Originally Posted by Sydwayz
Pic from Mark Rinda at MER Performance in SC:
What is MER doing to get 650 hp out of a 525? That seems to be the most HP I've seen someone claim out of these engines.
endeavour32 is offline
Old 04-05-2019 | 06:23 AM
they're adding stickers.
sutphen 30 is offline
Old 04-07-2019 | 06:00 AM
Did you ever re-dyno after the EFI was reinstalled?
not yet. I’ve been swamped with work. This week I’ll be putting everything back together etc. I’ll let you know once I have some numbers
tdbrickndirt is offline
Old 04-08-2019 | 09:09 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
I know Mark Rinda very well, but I can’t speak on his behalf for his technical expertise on engine building. He’s honest to a fault, so I know he’s not making claims he can’t back up. I have a lot of time riding and driving a 31’ Bullet with twin 825s that he built and they’re incredible. Give him a shout or look him up on FB.
Sydwayz is offline
Old 04-08-2019 | 07:29 PM
Mark at Mer built my 500 efi. Stroked to 540, afr heads, custom cam, and a modified 500 efi/525 intake with Tyler Crockett top mount throttle body kit. Best dyno pull was 693hp at 6000rpm. Jeff Wurl
jwurl is offline
