Using trs hydraulic steering on bravo drives
This is probably an ignorant question but here goes. I’m changing my trs drives over to bravo drives. Will my existing hydraulic steering work all the same with those drives. Thinking they are factory imco that came on my 12 meter |
No worries, as long as the throw on the rams work with the wing plate on the drives, in other words if the rams site in the same position with the drives neutral ( straight forward ) you'll be fine.
(Post 4672770)
Why are you changing from TRS to Bravo? Seems like that would be a net gain of 0
| All times are GMT -5. The time now is 11:25 PM. |
