Where’s my speed at? >
Where?s my speed at?
Old 02-16-2019 | 11:08 PM
Default Where’s my speed at?
I’ve got a 25’ 2’ 1990 Larson Senza Spectre with the 454 mag, bravo 1 with a 23pitch prop (365hp and 350hp at crankshaft). With 3 people (about 550lbs) and 3/4 tank (80 gallon tank) I run at 53mph (on GPS) @5500RPM... the RPMs seem a little high and speed seems low (even for an older boat). The 300hp test boat ran at 58mph on radar and the 230hp test boat ran at 41mph. This step hull runs 10mph faster than conventional hulls. Haven’t had a ton of time to mess with the boat and really play around so this is pretty much all of the info I have. What can I do to regain some speed?
Prestigeworldwideee is offline
Old 02-16-2019 | 11:30 PM
This is my favorite calculator, plug in your numbers.
Propeller Calculator / Prop Calculator
RBeyer is offline
Old 02-16-2019 | 11:33 PM
Have you checked gear ratio? It may be a 1.65
RBeyer is offline
Old 02-17-2019 | 06:51 AM
53 at 5500rpm sounds like a ton of slip if you have a 1.5 ratio drive.....something doesn’t add up.
I dont think the ECM will allow a 454mag to turn that fast unless it’s been reprogramed. Tach off?
liberator221 is offline
Old 02-17-2019 | 06:53 AM
Scratch that last statement, just realized you have a carbed engine.
Old 02-17-2019 | 11:16 AM
BUP
YEP 1990 stock OEM was all carb engines. And T Bolt 4 ignition so no rev limiter for any those. CARB engines T bolt 5 ignition did have a rev limiter and were 100 rpm over max WOT from the OEM.
BUP is offline
Old 02-17-2019 | 11:23 AM
BUP
compression test ?
condition of the props - any redone - Some prop shops do chitty repairs inreturn cost lower performance running condition. My area that is the norm - repaired props junk work
Timing and advance ?
Full Ignition tune up needed --- possible ?
check tach rpms to compare how accurate they are. The tach possible set on the WRONG pole setting would be a good guess here. Or inaccurate
Bottom of the hull spotless clean and do you have a painted bottom ? or a repair bottom. Check for hooks in the bottom of the hull.
IMPORTANT -- holding extra weight ? water logged ? or bringing water into the boat - ? Rotted wood ?
Is your Larson the one with the single Step hull bottom ( DDC) that Harry Schoell designed ?? If I recall correctly that hull bottom for Larson was in 1992 or 93 or 94 ? Forgot when that happened
BUP is offline
Old 02-17-2019 | 12:20 PM
Assuming your numbers are correct and it’s a 1.5 drive that’s a crazy high slip. I’d want to borrow a box stock prop and go from there.
Crude Intentions is offline
Old 02-17-2019 | 02:05 PM
I haven’t checked my gear ratio, I assume it’s 1.5 and it’s one step. The prop is the original 3-blade stainless steel quicksilver prop which seems to be flawless. I think everything is original on this boat, if it’s the 1.5 gear ratio, that’s means I’m getting like a 33% slip. I don’t know if the RPMs are right but that’s what I’m seeing. I can’t do anything right now as it’s winter here.
Old 02-17-2019 | 02:22 PM
Get a good timing light with a tach and you can check the accuracy when you get better weather. I would still try a box stock prop. Easiest thing to do. To see if the numbers change. The prop may look fine to your eyes but people knock and ding them a lot and get them repaired. Very easy to ruin a prop. Next I would go to a waterlogged type situation.
