-   -   CMI Air Actuated Mufflers (https://www.offshoreonly.com/forums/general-q/359211-cmi-air-actuated-mufflers.html)
endeavour32 02-25-2019 04:41 PM
Originally Posted by ICDEDPPL (Post 4674357)
https://cimg9.ibsrv.net/gimg/www.off...d5befc254f.jpg
The 2 lines coming out thru that square fitting.. no idea where you get it thou .
Thanks- I was thinking of making something exactly like that.
Alwhite00 02-25-2019 08:46 PM
Anyone have video of the open vs closed sound?
waveryd 02-25-2019 08:58 PM
Mine use Shakespeare or equivalent through hull fitting for VHF antenna coax for the air lines to the mufflers. Chrome plated brass with rubber seal. Newer pneumatic actuators from Parker on Amazon for $30 each use only one air line. Makes for a cleaner look. I'll try to upload a pic.
endeavour32 02-25-2019 09:06 PM
I thought about using the VHF fittings, but 8 of them would have been too much. I just ordered 4 custom plates like ICDEDPPL has on his boat.
Scarab28 02-26-2019 11:06 AM
Where did you get the 4 custom plates from?
Bajaboat77 02-26-2019 12:14 PM
J'achète du kit en France, les volets doivent être verticaux ou horizontaux? , J’ai installé des vérins électriques à l’intérieur du compartiment moteur, des coques usinées pour laisser passer une tige reliant le cylindre au silencieux.
Bajaboat77 02-26-2019 12:20 PM
error translation
endeavour32 02-27-2019 07:41 AM
Metals Cut 4U, I had them make 4, 1"x 2.5" plates, with polished stainless, 1/8" thick. I have a drill press at my house, so I'll drill the holes here.
Bajaboat77 02-27-2019 08:19 AM
I buy kit in France, the shutters must be vertical or horizontal? , I installed electric cylinders inside the engine compartment, machined shells to pass a rod of the electric cylinder to the muffler.
ICDEDPPL 02-27-2019 09:02 AM
Some other options:
https://www.defender.com/product.jsp?id=3411039
