CMI Air Actuated Mufflers >
Old 02-25-2019 | 04:41 PM
Originally Posted by ICDEDPPL
The 2 lines coming out thru that square fitting.. no idea where you get it thou .
Thanks- I was thinking of making something exactly like that.
endeavour32 is offline
Old 02-25-2019 | 08:46 PM
Anyone have video of the open vs closed sound?
Alwhite00 is offline
Old 02-25-2019 | 08:58 PM
Mine use Shakespeare or equivalent through hull fitting for VHF antenna coax for the air lines to the mufflers. Chrome plated brass with rubber seal. Newer pneumatic actuators from Parker on Amazon for $30 each use only one air line. Makes for a cleaner look. I'll try to upload a pic.
waveryd is offline
Old 02-25-2019 | 09:06 PM
I thought about using the VHF fittings, but 8 of them would have been too much. I just ordered 4 custom plates like ICDEDPPL has on his boat.
Old 02-26-2019 | 11:06 AM
Scarab28's Avatar
Where did you get the 4 custom plates from?
Scarab28 is offline
Old 02-26-2019 | 12:14 PM
J'achète du kit en France, les volets doivent être verticaux ou horizontaux? , J’ai installé des vérins électriques à l’intérieur du compartiment moteur, des coques usinées pour laisser passer une tige reliant le cylindre au silencieux.
Bajaboat77 is offline
Old 02-26-2019 | 12:20 PM
error translation
Old 02-27-2019 | 07:41 AM
Metals Cut 4U, I had them make 4, 1"x 2.5" plates, with polished stainless, 1/8" thick. I have a drill press at my house, so I'll drill the holes here.
Old 02-27-2019 | 08:19 AM
I buy kit in France, the shutters must be vertical or horizontal? , I installed electric cylinders inside the engine compartment, machined shells to pass a rod of the electric cylinder to the muffler.
Old 02-27-2019 | 09:02 AM
Some other options:
https://www.defender.com/product.jsp?id=3411039
ICDEDPPL is offline
